Amplifier HK PA 4000
Discussion in 'AV Receivers' started by mofet_n, Jun 8, 2003.
  1. mofet_n
    mofet_n Extra
    Apr 22, 2003
    21
    Hi! My home theater is set up as a 5.1 system (All polk audio spks RTi70, R50, CSi40). I find that my hk 325 isn't powerful enough, so I'm thinking of getting the HK PA 4000 (maybe you could recommend something else). Would I be able to power all 5 speakers, and would I be able to with my speakers and my receiver.
    If any of you have any comments about the PA 4000 or 2000, please write it down.
  2. Mark Russ
    Mark Russ Second Unit
    Jun 23, 2002
    341
    Mofet, you have all kinds of options. I personally would use 2 of the 4000's channels to passively biamp your cs400i center, and also passively biamp the rti70 mains with the other 2 channels of the 4000, along with 2 of your receiver's channels. Or, you could power a set of speakers in another room. The options are pratically limitless with that amp. It can power up 8 speakers at 45 watts per, if I remember correctly.
