AMP, XLR in
Discussion in 'Archived Threads 2001-2004' started by Troy_j, Jan 26, 2003.
  1. Troy_j
    Troy_j Agent
    Dec 1, 2002
    38
    HI and GO RAiders! I have a 3 pin XLR input on my new (old) amp. Do I need a preamp to connect it to my recievers VLF out? Or any thing else for that matter?
    I can send a pic too...
    Thank you for taking a look....
  2. Troy_j
    Troy_j Agent
    Dec 1, 2002
    38
    Also I have Phono jack in.....
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    send the pic...what amp and what receiver?
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,100
    33
    Katy, TX
    Wayne
    Troy,
    The XLR is a balanced input. Unless you have a pre-amp with balanced XLR outputs, there’s really no reason to use the amp’s XLR input. If you mix balanced and unbalanced connections, the result is an unbalanced signal – the same you get with regular RCA inputs. Not to mention, you will have to either custom-make some XLR to RCA cables – which is not something most people can do - or use adapters, which is kind of cheesy.
    Since you also have a phono input on the amp, I’d go that route.
    Wayne A. Pflughaupt
  5. Troy_j
    Troy_j Agent
    Dec 1, 2002
    38
    Thanks and this is my first try at importing a picture......
    [​IMG]
  6. Troy_j
    Troy_j Agent
    Dec 1, 2002
    38
  7. Troy_j
    Troy_j Agent
    Dec 1, 2002
    38
    [​IMG]
  8. Troy_j
    Troy_j Agent
    Dec 1, 2002
    38
    sorry for the huge pic...thanks too
  9. MarcVH
    MarcVH Second Unit
    Dec 26, 2001
    324
    I assume those jacks between the XLR jacks are 1/4" jacks, which typically can be used unbalanced with a simple RCA phono-to-1/4" converter.
  10. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    there are some products that'll take that RCA connection, interface it to an isolation transformer, and then output back to XLR. Rane makes this but I don't know the price. Also Ebtech makes something similar (under $100). Regardless, cables that go from RCA to XLR are readily available (do a google searh on "RCA to XLR").
  11. Troy_j
    Troy_j Agent
    Dec 1, 2002
    38
    Yes they are 1/4" .....thanks for the help. 1/4" phono to rca sounds like the way to go.
    Thanks, I knew I'd get excellent help.[​IMG]
