amp with shallow depth
Discussion in 'AV Receivers' started by DannyL, Nov 26, 2003.
  1. DannyL
    DannyL Stunt Coordinator
    Dec 18, 2001
    77
    i am currently running martin logan sl3's with an aragon 8008x3. we just purchased a new entertainment armoire and the aragon will not fit. any amps out there that aren't that deep- probably less than 14 inches? i know about the outlaw and marantz monoblocks. any other choice?
  2. Guyza
    Guyza Stunt Coordinator
    Dec 16, 2002
    60
    If the back panel of the entertainment is luan plywood (or some other thin wood), it's very easy to cut out a hole that allows clearance for the equipment. A slightly bigger patch can be used to cover up if you move the equipment.
  3. Phil A
    Phil A Producer
    Oct 1, 2000
    3,181
    44
    1,610
    Central FL
    Phil
    If you are looking for a 3-channel amp, it may be tougher. The old Adcom 555 is a 2-channel amp and not terribly deep. As noted above, it may be easier to cut some room for the binding posts.
