Amp voltage problem
Discussion in 'Archived Threads 2001-2004' started by mubashir, Apr 8, 2002.
  1. mubashir
    mubashir Agent
    Jan 13, 2002
    31
    My brother is in the states and am wondering would it be a good idea for me to ask him to get one of those parasound 2 channel amps here.The problem is the voltage difference(in Malaysia its 240 Volts compared to US's 110 Volts).Would buying a transformer solve the problem or is there any way he can get a 240V amp there.In Malaysia the prices of these amps are ridiculous.Do any of you guys know of a good quality amp that has a voltage selector?
  2. Jah-Wren Ryel
    Jah-Wren Ryel Stunt Coordinator
    Jun 7, 2000
    131
    I don't know about the parasound, but a lot of amps are dual voltage, if they have any sort of online manual or specifications, you should be able to determine if they are dual voltage from that. I think I saw that the Mondial Acurus's and Aragons are dual voltage.
  3. Mike_Ch
    Mike_Ch Stunt Coordinator
    Nov 26, 2001
    246
    Mubashir,
    What you can do is use a step-down transformer. Electronics shops usually sell these, and they convert 240/220V to 110/100V. According to most reports, they have no audible effect on sound reproduction. Cost is around US$50.
    Cheers,
    Mike
  4. mubashir
    mubashir Agent
    Jan 13, 2002
    31
    I'm just worried that the parasound needs so much power that these transformer might get too hot and burn up.I used to have a step-down transformer for my playstation and even that produced a lot of heat.
