Amp to make my AVR520 7.1??
Discussion in 'Archived Threads 2001-2004' started by John Carson, Feb 26, 2003.
  1. John Carson
    John Carson Agent
    Jan 30, 2003
    25
    Anyone have a suggestion for an amp to make my Harman Kardon 520 into a 7.1 revceiver?
    Can I use ANY amp that does left right and center?
    What do I need? HELP!
  2. Jeramy_K
    Jeramy_K Stunt Coordinator
    Jan 14, 2003
    83
    Hi John,
    You can use any 2ch amp for your extra surrounds. It's just a matter of personal preference. You just need to buy 2 RCA/RCA cables and connect the SBL/SBR Preamp Outputs to the amplifier.
  3. John Carson
    John Carson Agent
    Jan 30, 2003
    25
    So then an old bookshelf system would work to power those temporarily. [​IMG]
  4. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    Does anyone know if the amps on the 520 are assignable? If so you might want to pick up a decent 2ch amp for your mains and re-assign those internal amps to drive the surround backs... if that's an option w/ the 520.
  5. John Carson
    John Carson Agent
    Jan 30, 2003
    25
    I think they may be. On the back, there are sets of U-shaped RCA plugs that plug into the amp. They come pre-installed. I think you could take the U-shaped things out and re-rout (via RCA cables) any signal you want.
  6. Scott Pagac
    Scott Pagac Stunt Coordinator
    Jul 9, 2001
    114
    The 520's amp are assignable just as John describes.
    A nice match for the 520 is the H/K PA2000 power amp. I used it with the 520 to power the mains and re-routed the 520's main amps (FL/FR) to power the back surrounds. It sounded much better.
    I am now using the PA2000 to power the back surrounds with my AVR 8000.
  7. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    If you decide to use a PA2000, Scott's setup is probably the way to go (using the PA2000 to power the fronts). They provide a solid 100w per channel into both channels at 8 ohm bridged. For $217.66 shipped, it's hard to beat.
