rodneyH
- May 22, 2001
I need to know what amps to match up with which speakers. Here is what I have (getting).
Mains I KNOW what I will match
SPEAKERS
B&W 804s--->Marsh a400s(2X200w)
THIS is where I need the advice
Center=B&W HTM2
Rears=601
Amps
NAD 214 (2X80w)
Rotel 976 (3X150w-bridged)
both amps are about the SAME level (the rotel isn't their top of the line amp, and only cost about $600, while the NAD was around $400, so 1 isn't necessarily better than another, PLUS I really can't hear much difference between them).
SO, do I (btw, the room is very small)
Option 1 (Rotel 2X150 bi-amped to HTM2) and (Nad 2X80 to each rear 601)
use Rotel and BI-AMP the center channel (remember B&Ws are power hungry) with 2 (of the 3) by 150W (possibly a little over kill as far as power goes for a center, but I have always felt you can't have too much power).
Option 2 (Rotel 2X150 to 2 601 rears) and (Nad 2X80 to bi-amp HTM2)
is the 80w times 2 in a bi-amp configuration enough for the HTM2? and will the 150w too much for the 601s for the amount (or lack there of) of info to the rear and the lesser quality of the 601 VS the HTM2 (I am not saying they are bad, but certainly NOT the 800 series).
Option 3 (Rotel 3X150 to all the 3 speakers) and save shelf space
Although, I like the idea of having different power supplies and seperate amps for more headroom, less crosstalk, etc....
any advice is appreciated????
SPEAKERS
Center=B&W HTM2
Rears=601
Amps
NAD 214 (2X80w)
