Amp set up question
Discussion in 'AV Receivers' started by Bob_Lawrance, Aug 10, 2006.
  1. Bob_Lawrance
    Bob_Lawrance Stunt Coordinator
    Apr 14, 2002
    163
    Hey Guys,
    I have a Rotel RMB-1075 and RB-1070. With the RB-1070 being 130 watts for the two channels and the RMB-1075 being 120 by 5. Should I be using the 1070 for my fronts or just use them for my back surround speakers. I am thinking of using the 1070 for the fronts for a bit more power, not much I know.
    Thanks in advance.
  2. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    I would use the 1070 for fronts & 1075 for the rest. I can't think of a good reason to do otherwise.
  3. Seth=L
    Seth=L Screenwriter
    Jul 17, 2006
    1,313
    Yes, definitely use the 1070 for the front. If there is ever an instance where you want to listen to stereo programing you can use just the 2 channel amp, the other amp wouldn't even need to be on. Also the power issue, the 1070 has more power per channel and the front speakers are generally more demanding than surrounds.
    Seth=L
  4. Bob_Lawrance
    Apr 14, 2002
    163
    Thanks for the replys. It is what I thought but I wanted to make sure.
