amp recommendation (1 Viewer)
Tom_Price
Hi, can someone recommend a good 2 channel amp that puts out about 300 watts per channel?
I'm not really sure where to start looking for one.
TJ
Kevin_R_H
Hi TJ,
What is your price range? You can easily spend $30,000 if you want to.
Remember, "number of watts" does not equate to "quality of sound".
Good luck,
Kevin
Tom_Price
i'd like to stay around 500-1000 price range, but the only reason i say 300watts, is because my speakers are Polk Lsi25 and they are rated highest power rating of 300watts. It was just a figure to be a guide by.
Arthur S
Tom
You should be able to find a used Citation 7.1. This beast can be configured as 4X150 watts. 3 channel 2X150 plus 300+, or fully bridged for 2 channel at over 400 watts per channel.
The 7.1 listed for $2,800 when new.
I believe they can be had for less than $1,000.
Artie
PS They were designed from the ground up to run fully bridged so 4 ohms is not a strain at all.
Sihan Goi
I'm not sure how much it costs, but the Rotel RB-1090 sounds like a solid choice for a relatively low cost but high performing 2 channel amp with a high power rating(2x380W@8ohm)
Lee-M
McCormack DNA2 Deluxe... you can pick it up for $2000-2500, used. The sweetest-sounding solid-state I've heard.
Reddevil_23
