Amp Question
Discussion in 'AV Receivers' started by Leigh_M, Jun 19, 2004.
  1. Leigh_M
    Leigh_M Stunt Coordinator
    Feb 15, 2003
    152
    I have a yamaha receiver which only has an output for one set of mains. I would like to use this for my 5.1 HT as well as to drive some outside and bedroom speakers. Can I add an amp to do this? If so, how would I wire it and what would be some recommended amps?
  2. Leigh_M
    Feb 15, 2003
    152
  3. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    The easiest thing to do would probably be to run an integrated amp off of the tape output on your yamaha. This will allow seperate control settings in your auxillary areas while still letting you access your main source components. In addition, you wont be taxing the power supplies in your yamaha by asking your receiver to do more than it was really designed to.
    Good luck
    -rob
  4. Rob Rodier
    Jul 11, 2002
    538
    Good luck
    -rob
