Amp question: Is it possible to drive two rear speakers w/1 amp channel?
Discussion in 'Archived Threads 2001-2004' started by Keir H, Feb 28, 2002.
  1. Keir H
    Keir H Second Unit
    Jan 4, 2001
    462
    Just wondering...if that's possible. The amp is 80 watts and high current. The speakers are 8ohm. If so, how do you wire them in this experiment? thanks
  2. John Tompkins
    John Tompkins Supporting Actor
    Aug 30, 2000
    660
    Yes you can do it. But keep in mind that basically the amp will be seeing a 4 ohm load, so make sure its rated for that. Also you wont be able to calibrate the speakers to independent db settings.
  3. Brian Corr
    Brian Corr Supporting Actor
    May 10, 1999
    535
    But wouldn't you also only be receiving one channel of sound to the 2 rear speakers?
    In other words, how are the 2 independent channels going to be kept discrete when running off 1 channel of an amp since one RCA would be used from the amp to the receiver/pre/pro?
  4. Brandon B
    Brandon B Second Unit
    Mar 23, 2001
    263
    If he's doingf a rear 2 of a 7.1, they are playing the same information anyway. He just needs fudge his calibration (factor of 2) to get them loud enough.
    If you've only got one channel of amplification left, why not?
    edit: Oh, and in aswer to your question on wiring, in parallel will give you an apparent 4 ohm load with 8 ohm speakers.
    BB
  5. Michael Lee
    Michael Lee Supporting Actor
    Jan 7, 1998
    652
    Or perhaps you can wire it in series...wouldn't the amp see it as 16 ohms?
  6. Brandon B
    Mar 23, 2001
    263
    Yes, but that would half his available power, and unless 40 wpc is enough to keep up with the rest of the system, he might not be able to balance.
    Just thought of something else though. Is this one channel of a stereo amp? A lot of amps do NOT like to see different impedance loads on the 2 channels.
    BB
  7. Shad R
    Shad R Supporting Actor
    Oct 8, 2001
    536
    I was wondering this too...I am thinking of upgrading when Onkyo's 600 comes out(dts-es, dd-ex), and it only has one channel for the rear...so I wondering if I could run two from it too. This won't hurt the reciever at all?? also, does the new Onkyo have an output for the rear center(some do), if so, I can just use my old Onkyo to amplify it.
  8. Keir H
    Keir H Second Unit
    Jan 4, 2001
    462
    BTW guys, it's a five channel amp. I guess this would be only good if the info sent to the speakers is mono...??
