jeff cr
- Mar 2, 2002
okay, you say that to little power is worse for speakers than to much power because when the amps starts clipping then it is bad forthe speakers. My question is how do you know if your amp is clipping or not? for example my speakers sound great up until you turn the volume knob on the receiver to about 90% of full. then the speakers start to sound crappy and there is some distortion . Does this mean my amp is clipping at this point. also, if your amp is rated at 100 watts/ch and your speakers are rated at say 150 watts why does it hurt the speakers if the amp clips. thanks
