amp-only w/digital input ... does one exist?
Discussion in 'AV Receivers' started by Ted Lee, Aug 23, 2005.
  1. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi all -
    a friend was asking if a stand-alone amp existed that had an optical input. afaik, one does not ... but wasn't sure.
    does anybody know of one? oh yeah, it has to be inexpensive. [​IMG]
    thx!
  2. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    by "stand-alone" do you mean power-amp? if so, how would the amp decode the digital signals?
    there are the TacT digital amplifiers that have digital inputs, but they are expensive and don't say if they are optical. I guess there should be a couple.
    the same digital Equibit amps are powering the Panasonic XR series, so you might want to take a look at them (Panasonic XR55, XR70)
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    lol ... that's a good point and one i didn't even think of. no wonder they don't exist. [​IMG]
  4. FeisalK
    May 1, 2003
    1,245
    Also, AV123 are working on a cheap "fully digital integrated amp" called X-Empower (40W, $69 iirc, since the forum seems to be down when I posted this)
    I can only guess "fully digital" means that it will take a digital input, and that is directly converted to PWM (instead of a DAC stage)
  5. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    Ted
    Sony use to sell 'integrated amps' with digital inputs.
    I had one of their ES cd players that had it's own volume control and could go straight into a amp.
    The old "direct is better" concept.
    grant
  6. Danny Tse
    Danny Tse Producer
    Nov 1, 2000
    3,185
  7. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,218
    2
    The Yamaha takes an analogue signal (balanced or unbalanced) and amplifies it. A preamp would still be required.
    Sharp made an amplifier based on direct stream digital--it connected, via proprietary means, to a sacd transport. But it was still an integrated amplifier,
    Review of Sharp SM SX1000
