Amp kit for bass shakers
Discussion in 'Home Theater Projects' started by JasonWynia, May 27, 2005.
  1. JasonWynia
    JasonWynia Agent
    Nov 11, 2003
    28
    So, after reading in Make magazine about the fact that PartsExpress.com bought a truckload of bass shakers and were offering them at *dirt* cheap prices (under $30 a pair), I ordered a couple.
    http://www.partsexpress.com/pe/showd...number=299-027
    Now, I'm looking for an amp or an amp kit to drive them. The article talked about using "an old receiver" with the alternative being to buy a whole receiver. That seemed to completely ignore just going down the basic power amp route.
    Since they only need about 25W each to max out, a full-size receiver seems like both price and size overkill. So, I'm looking for either a homebrew amp kit or a plate amp, etc. in that 25Wx2 into 4Ohm range that also will fit with the fact that the shakers themselves have only set the project back $30, so dropping even $100 on an amp is going to feel wasteful even if it really isn't.
    If I could hide the amp inside the couch along with the shakers that would be a plus. My plan was to split the LFE output between my SVS and this new amp/shakers.
  2. Aaron Howell
    Aaron Howell Stunt Coordinator
    Nov 19, 2003
    196
  3. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    Just as Aaron suggested, inexpensive plate amps work great because you can also control the crossover point too. Thats what I use.
  4. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    if you want to try your hand at building an Amp
    Check out Chipamp.com the LM3875 stereo kit would do you just fine, all you would need is to get a transformer, some wire, RCA and binding posts, and your choice of case. theres tons of info out their under the term Gain Clone. all could be had for around 100 bucks or slightly more.
  5. Brad E
    Brad E Second Unit
    Jan 11, 2004
    304
  6. Dan Wesnor
    Dan Wesnor Second Unit
    Apr 28, 1999
    389
    You're going to need more than two...
  7. JasonWynia
    JasonWynia Agent
    Nov 11, 2003
    28
    Quite possible. However, I've got a box full of electronics that I was *certain* I would "need" and it turned out I didn't. So, I was sticking with ordering 2 and a matching amp, making a basic kit that could be repeated as necessary until I'm happy. In this case, it's not like skimping on the driver for a sub or main speaker. It's pretty much a raw count which can be augmented in a matter of a few days via UPS and VISA.
    I've also learned over time on this forum that "how much" is almost always a subjective subject with a really wide range of answers that are all true and correct ... to the person speaking.
    Before I bought my SVS, I was told that I needed at least 2 of them or it just wouldn't "fill the room". However, I bought one (and the smallest one they sell) it manages to shake the windows, flap the dog doors, and rattle anything loose anywhere in the basement.
    I ended up ordering one of the plate amps from partsexpress, though I may still look for a DIY amp and possibly another pair of shakers. I didn't get the 70W because every DIY project with these that I've read indicated that it's easy to overdrive them and you can get annoying extraneous noise. So, I grabbed the 25W stereo amp and will see how it goes.
  8. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    you know if i dident just upgrade my sub to 4 ava 18in i would get these. but i get so much bass it is scary.
  9. Brad E
    Brad E Second Unit
    Jan 11, 2004
    304
    Even your 4 18's won't reproduce this much vibration in a piece of furniture. Especially if your in the basement on a concrete floor.
  10. Bryan Michael
    Mar 2, 2002
    564
    yeah but you can realey feel them
  11. Garret_O
    Garret_O Agent
    Sep 11, 2002
    26
    I've been looking at these for a while myself.
    Anyone have any feedback on these:
    http://www.partsexpress.com/pe/showd...number=299-028
    vs the previous model:
    I'm thinking about building a platform for my fouton. Seems to me a pair with an amp would be nice for a single chair, but you'd want an array on a sofa. Then there is the larger Aura, advantages?
    The amps look nice, but are you all running a pair in series @ 8 ohms? Or are you dropping them down to 2ohms? Or possibly 2 pairs in a series/parallel combo to get it back to 4?
