Amp ideas for aura bass shakers pro? (1 Viewer)
Daniel I
Hey all!
Any ideas for an amp for Aura Bass Shakers pro. I don't have any older recievers to use. They are rated 50W RMS each and come as a pair ( 4 ohm ). Any ideas for a decent
cheap amplifier? I guess a mono 100 watt amp would suffice?
http://www.aurasound.com/
Thanks for any suggestions!
Daniel I
Nathan Crowell
You could purchase a plate subwoofer amplifier from partsexpress.com mcmelectronics.com or apexjr.com fairly cheaply. I know parts express has a 110 @ 8 ohm plate amp for around $100, but I haven't checked the rest recently. Make sure you wire your shakers in series, or else you will put a 2 ohm load on the amp, which will likely heat it up and make it go into protect mode. The $100 amp would put 55 watts into each shaker- perfect.
Jason Spencer
I was thinking of adding some Aura Pro's too. I've narrowed my amps down to: the partsexpress one; possibly buying a cheap (sony sawm20) sub and using its amp; or right now I'm really leaning to getting a cheap 2 channel amp (sherwood 100x2 at CCity). All these options should be around the $100 mark. One thing about the Sherwood (or similar spec) unit would be I could put 4 Auras (2 in the couch and 1 in each recliner) and still get close to 50 watt each. I know the amp won't be 100RMS per channel, but it should be more power total to the 4 shakers than the other amp ideas...
I've been very happy using an AudioSource Amp Two to power an array ( well, actually, two arrays ) of bass Shakers ( 14 in all ). I chose Audiosource due to it's ability to handle low impedance loads without complaining ( and it was cheap ).
DonnyD
I have two pairs of Pro Shakers with each pair being driven by a cheap "Audiofile" 150 watt amp that I got off Ebay for 59 bucks each. Its just a cheap plate amp but it works great and has been doing its thing for over a year with no problems so far.
BTW: Audiofile is the name of the amp.
linda19798888
