Amp Hook Up?
Discussion in 'Archived Threads 2001-2004' started by Bob_Lawrance, Mar 9, 2003.
  1. Bob_Lawrance
    Bob_Lawrance Stunt Coordinator
    Apr 14, 2002
    163
    Hello
    I have just purchased a rotel 1070 and I have a avr 520. I have never had an amp before, I was wondering when using the amp with the 520, how do I get the amp to turn on when I turn on the 520.
  2. Ken Custodio
    Ken Custodio Second Unit
    Dec 5, 2001
    316
    The 1070 has a 12V trigger in the back, tbe AVR 520 should also, you need to find or make a cable with the right connectors to fit between your receiver and amp. When your receiver turns on a low voltage current will cause your amp to turn on. If you do a search for 12v triggers you will find a good amount of message threads that have discussed this.
  3. Bob_Lawrance
    Apr 14, 2002
    163
    Hi Ken
    What can I use for the 12v trigger from the 520 to the amp?
  4. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
