amp for SVS
Discussion in 'Archived Threads 2001-2004' started by Anthony Moore, Dec 2, 2001.
  1. Anthony Moore
    Anthony Moore Supporting Actor
    Jul 12, 2001
    707
    i want an SVS bad. But should I get the amp they offer? I really would like to save some $$ if I could on the amp. But if its the best I can get for my money, then ill get it.
    I have the Denon 3802.
    what do you guys think?
  2. Marcelo T
    Marcelo T Stunt Coordinator
    Oct 21, 2001
    124
    Hey Jack, how do you adapted the plate amp to the CS sub?
  3. Anthony Moore
    Jul 12, 2001
    707
    I dont think ill ever want to add another sub....
    so what do youll recommend? the samson s700 still?
  4. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    If you'll never run it wide open, you could grab the $80 KLH receiver from BestBuy. TomV of SVS tried one, and got great results, I think it was within 3-5dB of what the Samson was doing.
    Remember that it takes double the power to get 3dB increase. So, a 400 watt amp will only give you 6dB more than a 100 watt amp. Unless you're going to be needing those last 5 or 6dB, you should be fine with something lower powered.
  5. Chad Isaacs
    Chad Isaacs Supporting Actor
    Feb 20, 2000
    757
    I am currently using an old yamaha 70wpc dpl reciver to power my 25-31cs.I am running the lfe out on my onkyo to the cd in and have it wired as a normal speaker.The reciever is set to stereo.I use the left speaker output to power my 2 shakers and everything works great.Been set like this for a while and no trouble at all.
    At first I was afraid that 70 watts would not be enough,well,it is!
  6. SVS-Ron
    SVS-Ron Screenwriter
    Jun 2, 2001
    1,074
    What Richard said.
    If you don't need any of the crossover featues of a plate amp (and you don't), then save yourself from making a box for the thing and just get one of those KLH receivers he mentions. You can even add a second SVS before you upgrade the power.
    Wiring is piece of cake and you don't need to do any bass boost defeat like you might on the Parts Express amps.
    Ron
  7. Jason Au
    Jason Au Extra
    Dec 2, 2001
    18
    Does anybody have a model number for that KLH reciever? The only one in my best buy is $100, the R 3000. I know it's just a twenty dollar difference, but want to make sure i'm getting the right one.
  8. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
