amp for my sub
Discussion in 'Archived Threads 2001-2004' started by warrick, Sep 6, 2002.
  1. warrick
    warrick Stunt Coordinator
    Jan 11, 2002
    75
    Hi All,
    I have found a place that has resurected my 12" Jaycar Subwoofer, the one I blew when building my Sono.
    Well my question is can I use any amp to power my next creation or will I need a sub amp as I was considering on seeing if there was something cheap on e-bay or at the local pawn shop
    regards
    Warrick
  2. Griff
    Griff Stunt Coordinator
    Jul 6, 2002
    53
    You can pretty much use any amp, it is just that you may miss the functionality that many plate amps offer, tone controls, high pass/ low pass filters etc.
    If you want sub amps, check out http://www.redgumaudio.com
    You will have to email them for info on their plate amps as it is not on the website (though i cant understand why it isnt).
  3. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    Here's a 120 watt sub amp for $80 USD.
    You actually don't need a subwoofer amplifier. If you could find a stereo receiver and bridge it, that could be used to power your sub just fine. If the driver's sensitive enough for your tastes, you could even use a single channel off the receiver.
  4. Griff
    Jul 6, 2002
    53
    Thats a US sub amp, 120 volt, incompatable with the Oz 240 volt.
  5. warrick
    Jan 11, 2002
    75
    Griff,
    Thanks for the reply but the redgum amps retail from $450 delivered and that is a little more than I intended to spend(or what the wife will allow me to spend) Still open to any other suggestions from Down Under.
    Chris
    When you bridge a stereo amp does it have to be a special sort or can this be done with any amp ??
    Regards
    Warrick
  6. Chris Tsutsui
    Feb 1, 2002
    1,865
    Well the stereo amp or receiver should say "Bridgeable" on it. The amp would then be combining both stereo channels into one and provide more power.
