Amp fan
Discussion in 'AV Receivers' started by Scott Andrew, Apr 3, 2006.
  1. Scott Andrew
    Scott Andrew Stunt Coordinator
    Nov 9, 2004
    63
    I have a Pioneer 1014 and the only option for the rack is to have only about 1 inch of space above the amp, now I know this is very bad so I want to get a few amp fans to help with dissapating the heat, I can put 1 fan on top near the back and then maybe two on the sides. Does anyone have any ideas of which fans might work the best? I went to a surplus store to buy some fans and they had about 10 to choose from with different voltages and then how can they be hooked up?
  2. Peter f
    Peter f Stunt Coordinator
    Mar 14, 2000
    111
    If you have the room for it, I highly recommend the Parasound Z-Breeze. I recently added one to my cabinet and am amazed at the cooling capacity from such a small unit
