Jonathan Barr
- Jan 6, 2006
Hi folks, first post, I'm at my wits end here!
I have a problem that's popped up with my amp/speakers and I'm at a loss to explain it, so I've come to see if any of you could help at all.
I have a Marantz 5200 amp and a set of 5 Mission speakers.
As a test I removed all connections to the amp, bar power and one cable to a front speaker, then I connect in the TV via phono. Whenever I try to output the audio through the speakers I get a hiss and a crackle when in digital mode, however when I select Source Direct mode (straight to analogue) there is no hiss at all. So it's fine for 2 speakers for playing music but for movies or TV (when digital mode is needed) there hiss is unbearable, it's so loud. I have tested other speakers, different speaker cable and another device other than the TV.
One last point is that when in surround mode only the front two speakers exhibit the problem, the surrounds are fine.
Any ideas? Is my amp buggared?
Any help would be appreciated! If any more detail is needed just ask.
Jonny
Jonny
