Amp channel use question
Discussion in 'AV Receivers' started by Pesiba, Sep 4, 2004.
  1. Pesiba
    Pesiba Extra
    Oct 15, 2003
    23
    Hello everyone!
    I have an H/K PA-5800 (5x80W) driving the center and surround L/R speakers while the H/K PA-2000 drives the main Front L/R speakers. I like the setup as is however I'd like to know whether not using the other channels will damage the PA-5800? Or will the channels now in use degrade over time since these are being used more than the other channels? Does it matter whether the other channels on the amp (PA-5800) are used at all? I'll appreciate some feedback. Thanks
    Pesiba
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,099
    33
    Katy, TX
    Wayne
    No, it doesn’t hurt not to use a channel. As long is it isn’t getting an input signal it’s just sitting there.
    Sound degradation with the used channels vs. the unused should be a non-issue. I have amps that are at least 15 years old and they’re still going strong. More than likely you will sell or upgrade equipment long before this becomes an issue.
    Wayne A. Pflughaupt
  3. Pesiba
    Pesiba Extra
    Oct 15, 2003
    23
    Wayne, thanks a lot.
    Pesiba
