Michael Giusto
Grip
- Jul 14, 1998
I have a Toshiba TW40H80 16:9 TV
with a Toshiba SD-3109 DVD Player
and last night when watching "Die Another Day"
was bothered by how big the black bars are
above and below the image. If you add them
together, they may be the same vertical width
of the movie image.
With my components should these black bars be
this large or do I need a Digital 16:9 set,
also what constitutes a Digital 16:9 set, I
didn't know that there is a difference. I do
have my set conected to the DVD player using
component cables.
I'm at work right now and can't play around with
any settings, but I am thinking that maybe my DVD
output settings got erased when I had the DVD
player disconnected about 2 months ago. I've had
this same problem with other 2.35:1 movies but
was completely fed up with "Die Another Day" last
night. My DVD player prior to being plugged in
was set for display on a 16:9 screen.
So my basic question is as simple as this. Do I just
need a setting change on my DVD player, or do I need
a Digital 16:9 TV (or both).
Thanks for any help!
of the movie image.
component cables.
