Am I Ordering the Right Cables?
Discussion in 'Accessories, Cables, and Remotes' started by Todd_K, Jun 24, 2003.
  1. Todd_K
    Todd_K Extra
    Nov 6, 2002
    20
    Hello, I was wondering if someone would check my work before I go and place an order for some cables for my new home theater.
    Here is my equitment:
    Mits 55411
    PS2
    Onkyo SR800
    The way I was going to do is:
    Run Audio/Video and S-Video from Reciever to the TV
    Run Component Cables from PS2 to TV
    Run Optical from PS2 to Reciever
    So what I was going to order was from Blue Jeans, Belden 89259 Audio Cables, 1694a Video and a S-Video Cable. Already have the optical and Component cabels for the PS2.
    Is this right? Please help!!
    Todd
  2. adamKI
    adamKI Stunt Coordinator
    May 10, 2003
    107
    Why are you running S-video between TV and receiver? Do you have multiple S-video components that you didn't list?
    Also, do you have a DVD player that will run on component also? If so, you probably want to run component from receiver to TV then component from Receiver to DVD and PS2 and let the Reciever do the switching.
    Otherwise, it looks OK.
  3. Todd_K
    Todd_K Extra
    Nov 6, 2002
    20
    Thanks for the response. I thought I was suppose to run component directly to the TV from DVD or PS2, not through reciever for the best picture.
    According to manual for TV I need to run Audio/Video AND either a Video or S-Video to monitor out. Is this right?
  4. adamKI
    May 10, 2003
    107
    I have one of the predecessors to your Reciever, the 787 and it switches high definition component just fine. HOWEVER, if you only have one device running on component, you're right, just plug it straight into the TV.
    As for S-Video, if you're just sending the sound from the TV to your receiver then, no, you don't need to run video out to the receiver. You may want to run S-video from one of the receiver's outputs to your TV's S-video INPUT so you can see the On-Screen-Display.
  5. Eric Stuckey
    Eric Stuckey Second Unit
    Mar 24, 1999
    421
