am I doing the right thing
Discussion in 'Archived Threads 2001-2004' started by gene avallon, Feb 1, 2002.
  1. gene avallon
    gene avallon Stunt Coordinator
    Jun 13, 2001
    187
    I just got my two 46 plus,that sure was the right thing.I also have a order in for the OUTLAW 950,and 770, is this the right thing to do?
    thanks
    gene[​IMG]
  2. JackS
    JackS Supporting Actor
    Jan 17, 2002
    634
    If I were your neighbor, I'd say no. Other than that, I'd say absolutly. Should be great fun for a while until you get that knock on the door. Kidding aside, sounds wonderful to me. Luck ,Jack
  3. gene avallon
    Jun 13, 2001
    187
    come on theres got to be some cons about these two,it cant be that easy
    gene
  4. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    ...the two units are coming with a good buzz, but you'll still be buying without any extensive consumer roadtestings...
  5. gene avallon
    Jun 13, 2001
    187
    bill
    how is there past history on new products?
    gene[​IMG] [​IMG]
  6. Legairre
    Legairre Supporting Actor
    Apr 4, 2000
    815
    Depending on the size of the power supplies. Having 7 channels using them at once could be a negative. Based on the weight of the amp(76lbs) it sounds like the power supplies are not large or that Outlaw has found a way to use smaller power supplies and get a lot of power. Most 5 channel amps in the 200wpc range weigh 75-90lbs, so a 7 channel amp that weighs 76lbs might have small power supplies. I wish Outlaw would publish the size of the power supplies and other specs.
