Aluminum Speaker terminal (1 Viewer)
Chris Tsutsui
Just thought I'd share my one of a kind speaker terminal link.
It's my first DIY site, let me know if I should change anything before I start building a DIY tempest and soldering site.
I know, it may be dumb but I had the spare time and nothing's too much for my tempest. :)
James W. Johnson
If your hand starts to burn you are holding it too close to the flame.
You probably just saved a bunch of terminal cup tweakers a burnt hand. :)
Actually its not safe to hold any flammable substance such as spray paint next to a gas flame.
The proper way is to be patient.. spray a coat and wait til it drys for the next coat.
atlanticshores
