Alternative to T-Nuts?
Discussion in 'Archived Threads 2001-2004' started by Seungsoo Hwang, May 9, 2001.
  1. Seungsoo Hwang
    Seungsoo Hwang Stunt Coordinator
    Aug 6, 1999
    204
    My sealed shiva is moving along slowly but steadily, and I have run into a slight problem. I am flush-mounting the driver, and it appears that t-nuts will not fit on the edge of the driver cutout without going over. (also, I made the mistake of puttin the box together before putting in the t-nuts, so I was screwed anyways). Is there an alternative to t-nuts that I can use in my current situation, or am I just going to have to screw into bare MDF?
    thanks!
  2. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Hmm, T-nuts should be pulled in either with a clamp or bolt/washer, so having it already built doesn't matter. If one pointer is over the edge it shouldn't matter. There are threaded inserts for wood available if this is what you prefer.
    What size T-nut do you use? Mine are 3/4" dia for 1/4-28 machine bolts, plenty small to fit, unless you made the cutout too big to begin with.
    GM
    Loud is beautiful, if it's clean
  3. Seungsoo Hwang
    Aug 6, 1999
    204
    i believe they are 10/32 x 5/16"...Hehe I've been pounding them in with a hammer all this time, good to know how it is actually supposed to be done. Maybe I should get some smaller tnuts/bolts... The cutout is fine, I guess I'm still good to go then.
    thanks a bunch.
  4. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
  5. Seungsoo Hwang
    Aug 6, 1999
    204
    Those panel connectors are pretty interesting...do they have them at home depot? BrianW says he hammered them in, which is what I can't do, I doubt those will like being pulled in with clamps?
  6. Greg Monfort
    May 30, 2000
    884
    Again, seating them by using an appropriate bolt/flat washer to pull them into place is a viable method.
    BTW, 10-32 seems a bit small for 12"-up drivers.
    GM
  7. Brian Fellmeth
    Jul 30, 2000
    789
    Anyone know a source for those giant T nuts in Brian Bunge's second link ?
  8. Ellen
    Ellen Stunt Coordinator
    Jan 8, 2000
    142
    Ellen
