Greg S
- Mar 13, 2000
All Credit goes to DVDTALK members for this.
CLICK IT FOR THE DEAL!
This is at BB.
The best thing to do is order it online using instore pickup. Should work fine as it worked perfectly for me when I got mine this AM.
OR YOU COULD TRY THIS!!!
Just got back from doing a Pricematch at CC.
Got mine for $7.99!!!
Just put it in your cart, go to checkout select instore pickup and choose your store. Print out that page and take it to CC and they should PM it for you. They may freak a bit since its $29.99 there but will eventually just do it.
*** Be sure to explain to them how the printout that you gave them shows that it is available for instore pickup at the $9.99 price.
This should work fine as I have done this numerous times at CC but as with any PM YMMV!
Best of Luck
** I should mention that I have no idea how long this will last as there are plenty of DVDTALKers getting on this. I think the PM at CC (or somewhere else) is the best choice.
Greg
This is at BB.
Best of Luck
Greg
