Stas T
- Sep 2, 2001
Was there ever or is there still or will there ever be an Aliens disc featuring the theatrical cut? Thanks for any info.
Are you saying that the current DVD was mastered from video and not from film?
Correct. The longer cut was assembled on video only. Obviously not VHS though
The extended version of The Abyss was created on film and received a short theatrical run.
It would be lovely to have a theatrical/extended disc using seamless branching. Not sure if that will ever happen though. The longer cut only exists on (professional) video, unlike The Abyss which had it's extended cut created on film.
What does that have to do with branching?
Continuity: When Ripley retrieves some weapons to rescue Newt, she picks up one weapon from the rack, puts a different one down on the floor, picks up the second weapon from the rack, and puts the first one down on the floor. This is fixed in the special edition.
This is a quote from IMDB, and it's correct! In the theatrical cut a cutting error was made, so that a flamethrower became a pulse rifle and vice versa. This is fixed in all special editions UP TO THIS DVD!!!
What I'm saying is: The DVD cut still contains the cutting error (I'm 100% certain, I've checked several times). So that means this version wasn't sourced from the same master as the previous versions! Surprised?
Well, me too when I found out!
~ Stud. Polyt. ~ Artur Meinild ~
There'd be a good chance of a change in 'look' when branching from one version to another.
Why? There's no change in "look" on the current DVD of the extended version. If they added branching such that you could play the theatrical version by skipping over the extra scenes, what would change?
