Alexander: The 2 Cuts
Discussion in 'DVD' started by RogerH, Mar 20, 2006.
  1. RogerH
    RogerH Supporting Actor
    Oct 28, 2004
    877
    I know alot of people didn't like this movie but if you had to choose which one is better the director's cut or the theatrical cut?
  2. PaulP
    PaulP Producer
    Oct 22, 2001
    3,291
    Since the extras are different, I had to go with both.
  3. Nathan V
    Nathan V Supporting Actor
    Jul 16, 2002
    960
    There are already at least two massive threads about this. Try the search feature again.
    Nathan
  4. Matthew Marino
    Matthew Marino Stunt Coordinator
    Apr 24, 2003
    185
    I'd probably give a slight nod to the theatrical. Possibly because I saw it first. I do own both however and don't plan on getting rid of either.
  5. Justin Bauer
    Justin Bauer Supporting Actor
    Feb 19, 2003
    553
    I am a fan of the movie despite the editing/acting flaws.
    Get the theatrical cut, it is much better. I am still amazed that they failed to correct the editing problems on the director's cut and just created more.
    However, if you want a shorter movie with less narration and oration from Ptolemy (Hopkins), then pick up the DC.
  6. Randy Korstick
    Randy Korstick Producer
    Feb 24, 2000
    3,694
    1,411
    4,110
    Well, I didn't see the theatrical because of all the negative feedback. Rented the directors and liked it alot more than I thought I would and thought the directors cut was the reason I liked it. I should probably see the theatrical to compare.
  7. Nathan V
    Jul 16, 2002
    960
    Rent both. Then buy the DC [​IMG]
    I vastly prefer the director's cut (which Stone calls the "10 month cut," as opposed to the 7 month theatrical), for its thematic clarity, eliminaton of redundant and/or unnecessary moments, and sharper editing and pacing. The decision to juxtapose his young life with this adult life in the 10 month version (this was how it actually was in the original script, the move to an all linear plot for the theatrical release was a last minute decision for the sake of coherence) makes for a much stronger dramatic arc, and offers for some powerful punches in the last 2 acts of the film; also, this move avoids frontloading by keeping Val Kilmer and Jolie in the entire movie, as opposed to just the first act. It also makes the cut to Philip's assassination less jarring, as the whole film is intercut. Structurally it is quite similar to Oliver Stone's (masterpiece) Nixon, which intercuts Nixon's childhood with his presidency. Also, the Indian battle seems to be even more ferocious on the DC; I suspect that it's been srpuced up, not unlike the LOTR: EE's. It should be noted that the DC is not merely a reshuffling of scenes; MOST of the scenes in the film are either subtly or dramatically altered, whether it be a few snippets added here, a couple seconds dropped there, a shot cut away a little sonner, or an alternate take. The refinements are pervasive, both large and small. Editing enthusiasts like myself should have a field day. Here is one of my megaposts concerning the new version of Alexander - http://www.hometheaterforum.com/htfo...46#post2752746
    I suggest going through that whole thread, as there are a number of intelligently articulated (and wildly differing) views on the film that will hopefully help you make your decision.
    Nathan
