Aktis RC-8000 System call
Discussion in 'Archived Threads 2001-2004' started by Dave Pobuda, Jan 7, 2003.
  1. Dave Pobuda
    Dave Pobuda Stunt Coordinator
    Dec 25, 1999
    82
    I found a code that allows me to have direct access to the different inputs on my Mits WT-46809 TV by only using one button on my remote. I learned the command to a button on my Aktis RC-8000 and it works great! One button access to the DVD input. I've tried putting the command in to the system call,everything works except for this button. Any help would be appreciated.
    Dave
  2. Mike OConnell
    Mike OConnell Second Unit
    Jun 14, 1999
    489
    Overland Park KS
    Mike
    Dave:
    When I programmed my Aktis (have since replaced with a Pronto), I also had direct access codes for my Mitsubishi inputs that I learned into my Aktis.
    They worked fine when just pushing the button, but in the sys-call they did not. The problem was with the duration of the IR signal, it was too short as a single command, so I repeated the command in the sys-call three or four times (I think - I kept adding until it worked and then added an extra) and this kept the duration long enough to change the input.
    Good luck!
    Mike
