Aiwa D57 problems.. advanced help?
Discussion in 'AV Receivers' started by Adam Smith, Jan 12, 2005.
  1. Adam Smith
    Adam Smith Agent
    May 27, 2003
    26
    Hello. My Aiwa AV-D57 no longer powers on. It doesn't smoke or show any signs of a short.. but nothing happens. I found that this wire is unplugged, and I don't know what it is.
    *PIC*
    Can anyone tell me where it goes? I've looked high and low through the receiver's circuit boards and can't find a connector that it plugs into. It's coming off the power transformer board so I think that may be why it's not turning on.
    Well apparently I can't post an image because I'm too new to the board, so you can find it here:
    teamcaf(dot)org/upload/aiwa-d57.jpg
  2. Adam Smith
    Adam Smith Agent
    May 27, 2003
    26
    Bump. Any answers? [​IMG]
  3. Adam Smith
    Adam Smith Agent
    May 27, 2003
    26
    Hmmmmm. Someone say something please!
  4. Adam Smith
    Adam Smith Agent
    May 27, 2003
    26
    Well this isn't working so well so far. [​IMG]
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    Hmmm, any answers... Well it would be tough with a scematic of some sort, if you can't find an obvious place that wire would have been attached...
    It would probably be just a feed through hole on a circuit board. Maybe even one that appears to have no solder in it.
    Hard to say.
  6. Adam Smith
    Adam Smith Agent
    May 27, 2003
    26
    Well, I still don't know where it goes but I think I know what it does. I finally got my multimeter (I bought it off eBay for $7.. gotta love eBay) and two of the four pins test at 17 VDC. I'm pretty sure it's used to power the front LCD and operate the buttons. I think the other two pins are part of a "Power good" signal. We'll see.
  7. steve-gos
    steve-gos Auditioning
    Jun 6, 2005
    12
    I was just reading you post - did you ever fix this? I have the same problem with a used AV D57 that I just bought off of ebay.
  8. chuckg
    chuckg Supporting Actor
    Apr 27, 2004
    917
    I have concocted a small web page with pictures of the insides of my AV-D57. I too have had trouble with power-up; it generally takes three tries to get it to come on.
    http://www.brevardcc.edu/planet/AV-D57/index.html
    in case I can't post links:
    aitch tea teepee colon slash slash
    triple double yew dot
    Hope you can get it fixed!
    ps. anybody wanna buy a recently retired AV-D57? has everything but the box.
