AGP 1x/2x/4x (1 Viewer)
Chris Bardon
Quick question-I just upgraded my MB, and the old board only supported AGP 1x, but the new one (and my graphics card) support AGP 4x. Is there any way to tell if the card is making use of this transfer rate, or should it by default? I know that my old TNT2 had a jumper that you had to set, but the ATI doesn't seem to have anything. There's also nothing that I can find in the CMOS to indicate anything about the AGP slot. Just want to make sure that I'm getting the most out of my card.
Arthur Legardo
ArthurL
There's a utility called SiSoft Sandra, I assume by SiSoft, that can tell you this information. You can probably find it in most shareware sites.
linda19798888
