ronTU
- May 9, 2006
I have the following setup:
HTPC:
1) CPU - Pentium4 2.8ghz 800 FSB
2) RAM - 1GB dual channel
3) HD - Seagate 80gb SATA & Seagate 300gb SATA
4) Video Card - eVga 7600GT CO
5) Digiwave 103G DVB card
Projetor:
Panasonic AE500U
Problem:
When I use my Bell 811 receiver to watch HDTV (using the DVI out), I get an amazing quality. When I watch Superbit DVDs on my Samsung HDTV DVD player (using DVI out) I get the same amazing quality. But when I use my HTPC (using DVI out) I get a blurry image no matter what codec I use. It's wierd how the same feed using my 19" LCD (vga port) gives me a crisp and clear image quality. I get the same results using Component. The image is blurry especially when there is allot of movement in the image. I never got that with my Bell or DVD player. Also, I polayed Xbox 360 on this projector and the quality was amazing as well, it is only when I pluged it to my PC that this occurs.
I really don't know why this occurs...Is there a way to fix this or this?? Hope so
HTPC:
Projetor:
Panasonic AE500U
Problem:
