Advise for a HT Club combo setup (1 Viewer)
csh
chandan
So we are finishing our basement and i want a decent HT setup. We do entertain a lot so wife wants a club like setup (dance party with around 30 guests who like loud music). Our basement is open and we want it to stay open as much as possible so want to avoid speakers on the floor and out budget for everything including screen, speakers, amp, sub is max 8K CAD (maybe a bit more). I can run power/speaker wires myself. Can you guys make recommendations on
1) Speakers/sub with high enough SPL to produce club like sound as well as good HT sound.
2) Speaker placement in the complicated open basement
3) Cost around 8K CAD
4) Screen and AMP recommendations
5) Anything else i should think of
csh
chandan
I spoke to a local vendor and they are proposing the following for around $14K. What are your thoughts on if i will be able to get club like SPL
Elunevision reference studio 4k audioweave screen slim (0.75 thin bezel), 125” 16:9
JVC NZ3 Projector
Denon 3700H 9.2 channel receiver (4k/8k)
Speakercraft Profile aim cinema one x3 (behind the screen)
https://www.speakercraft.com/product/profile-aim-cinema-one-ASM59101
Dynamic audio labs 6.5” in-ceiling x6
https://www.dynamicaudiolabs.com/kvsc-65.html
martin logan dynamo subwoofer 1100X (12” sub)
https://www.martinlogan.com/en/product/dynamo-1100x
ManW_TheUncool
His Own Fool
The BK
ManW
Probably not recommendable to do both dance party club-like setup and reasonably good HT sound w/ one combined system in that space.
Should probably go w/ 2 (largely) separate systems.
How often do you really intend to run these dance parties anyway??? If not that often, maybe you should just rent some PA gear for such (and only buy for the HT itself)...
_Man_
ManW_TheUncool
His Own Fool
The BK
ManW
Probably 60-70% of time for dance parties
How often is that??? 60-70% of 365 days/year is 219-256 days/year! I'll assume you're not actually doing 24-hour parties... :lol:
IF really that often, I hope you're getting paid well to run them... :oops:
_Man_
Dave Upton
Audiophile
Houston, TX
Dave Upton
If you want to do both in one system, stay far away from what you were quoted. It's a truly abysmal solution.
Go get some speakers meant to play loud. I would suggest these:
You'll also need at least 2 subs to get club levels of bass. I would recommend going with SVS, PowerSoundAudio, Rythmik or JTR there too.
What is your budget?
csh
chandan
LOL i mean 60 70% of the use.
So say every fri sat is party and sunday is movie
csh
chandan
budget for everything is 10K CAD around 8k usd
JohnRice
Bounded In a Nutshell
A Mile High
Dave's right that you need much more substantial speakers than were recommended. You won't accomplish your goals with in-wall/ceiling speakers. You'll also need more power than a receiver will provide, though you can use that Denon as a head unit with external amps.
I have to question if a projection system is really ideal for a multi-use room, rather than an LED based TV.
Strubdog
