Advice
Discussion in 'Computers' started by Carl Gaff, Apr 29, 2003.
  1. Carl Gaff
    Carl Gaff Second Unit
    Jan 26, 2002
    281
    My son is currently in the process of building a new computer for me (he does computer stuff and I do home theater stuff). I'm having him install a good video card and a large hard drive so I can record TV broadcasts.
    Here's my dilemma: My computer is in one room and my Mitsubishi big screen is in another. What's the best (meaning easiest)way to get the signal from my computer to my tv so I can watch my pre-recorded shows?
    Any help would be greatly appriciated.
    Carl Gafford
  2. David_N
    David_N Stunt Coordinator
    Sep 4, 2001
    205
    When I used to use my PC record TV in the other room I just used a long cable. It worked for me since I could run the cable behind furniture so it wasn't easily visible. But you could always drill some holes through walls.[​IMG]
  3. Carl Gaff
    Jan 26, 2002
    281
    Thanks for the info Dave. What type of cable did you run?
    Carl
  4. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    I use a 50ft Svid cable for my run to the Living from the computer (with a 50ft RCA cable for digi-coax) and then for the Living room to the computer I used a RCA->coax converter box and use the TV tuner in my comp to pick up the second room output.
  5. Carl Gaff
    Jan 26, 2002
    281
    Thanks Rob. I was leaning towards your solution since I have a couple of extra Camelot s-video amps lying around. I hate the thought of crawling around in the attic (isulation)again, but for a good picture I guess it's worth it.
    Carl
