Tony Bensley
I’m hoping to order a 4K UHD Blu-ray playable Disc Drive in the next few weeks.
While I have a number of questions, the main one at the moment is for 4K UHD Blu-ray disc playback, the LG drive I’m looking at is the only one that is normally priced at well under $200, and doesn’t come with Cyberlink bloatware, which I would just as soon do without. It also has 3-D support, on the off chance I ever get a display with that capability. For playback purposes, does it matter if the USB is set up for 2.0, or should I be looking at USB 3.0 UHD Drives for this purpose? As it stands, this particular drive is out of stock on Amazon Canada far more often than not.
Regarding 4K UHD Blu-ray playback compatibility through my device configuration, I’ll be attaching screenshots with some key specs. Insofar as screen resolution, my Acer Laptop is limited to 1920x1080p with my Toshiba TV further limited to roughly 720p. At this time, UHD Blu-ray playback capability is what I am after. My current playback software is the free version of Leawo, which is 4K playback capable. “Use HDR” is not supported for either of my “Internal Display”/“TOSHIBA – TV” options, although HDR for streaming is supported with the former option.
Any and all input would be greatly appreciated!
CHEERS!
CHEERS!
