Advice on center channel to match Klipsch in wall speakers
Discussion in 'Speakers & Subwoofers' started by Mark Thiessen, Dec 29, 2003.
  1. Mark Thiessen
    Mark Thiessen Auditioning
    Oct 26, 2003
    5
    I bought a house with 4 Klipsch in wall speakers installed (IW-100 or IW-200). I just got a Harmon Kardon AVR 325 and now I'm in search of a center channel speaker that matches the in wall speakers. I'm new to HT and find these message boards very helpful.
    What do you think of the SC-1? They don't sell it anymore but I can find them on ebay. I'm not familiar with the Klipsch line. Is there a more current Klipsch center speaker I should look at?
    Thanks in advance,
    Mark
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Why not just order another single in-wall?
  3. Mark Thiessen
    Oct 26, 2003
    5
    Getting another in wall isn't an option because of the way the room is configured. I really need a portable speaker.
  4. Chris A H
    Chris A H Stunt Coordinator
    May 10, 2002
    172
    The IW series uses a older non-horn tweeter, so any of the current horn-based centers will have a different "sound" to them. This could cause imaging problem in the front soundstage, or it could work fine. Would be best if you could get one to try out before buying one.
    I do have the SC-C1 center with the matched KSB 3.1 fronts, and it is an great center channel speaker. Dialog is always clear and understandable.
