advice on cable runs.................
Discussion in 'Archived Threads 2001-2004' started by KevinW, Aug 21, 2001.
  1. KevinW
    KevinW Stunt Coordinator
    Dec 11, 2000
    187
    Is it possible to run cable from attic down through an exterior wall? If so, can you offer some advice on how to do it?
  2. James Reyes
    James Reyes Stunt Coordinator
    Jul 24, 2001
    66
    What do you mean? I am picturing a hole in the ceiling by a wall and cable tacked down it. Why would you want to do it like that rather than fish it through the wall and install a wall plate at the bottom?
  3. KevinW
    Dec 11, 2000
    187
    James, running it down through the inside of the wall is what I want to do. I've done it many times in the past with cable and speaker wires through interior walls, but never down through an exterior wall filled with insulation. Won't this make it really difficult or damn near impossible?
  4. Scott Kimball
    Scott Kimball Screenwriter
    May 8, 2000
    1,500
    Insulation does make it more challenging.
    If the paper is intact on the front of the insulation, the job will be easier. The best way I know is to get some flexible fiberglass fish rods (not fishING rods, but rods that are designed to do what you're trying to do).
    These are usually about 6' in length, and are stackable. The lead rod should have a ball of some sort on the end (so as to keep the thin rod from puncturing insulation paper). Get a few of these rods from a hardware store or electrical supply company, tape the cable firmly just behind the lead ball, and carefully work the rod between the insulation paper and the wallboard. This takes patience and practice.
    Good luck.
    -Scott
  5. KevinW
    Dec 11, 2000
    187
    Thanks for the info Scott! It looks like I've got a nice project for this weekend. [​IMG]
  6. James Reyes
    Jul 24, 2001
    66
    OH, duh!! I see what you mean, Kevin. That's exactly what I used to do, Scott. Good advice.
