Ricky Hustle
- May 29, 2000
Hello all, here's my situation.
I own Klipsch reference all around, RF-5's up front, RC-35 center and RS-35's in the rear. An SVS 20-39 PCi subwoofer completes my setup. I'm extremely happy with my equipment.
I moved last year, and my new viewing space is smaller than I had in my old house. My primary seating is right up against the back wall, and it's not really an option to move it up a few feet. That would put me too close to my 65" Mits.
The surrounds are mounted on the back wall facing the screen. Putting them on the sides facing in can't work because one side of the room is open. We're not too happy with how it sounds, as the rears pretty much disappear and bounce off the front wall now. Our listening experience is not what it once was when the rears were a few feet behind the listening position.
I realize that the surrounds do not have to be as robust as the rest of the system to be effective as long as they are placed correctly, and I also think that my RS-35's are a bit of overkill (they are huge). I'm contemplating getting two new smaller speakers and hanging them from the ceiling, off to the sides of the couch and facing inwards. Klipsch doesnt offer any smaller surrounds, only the in-wall variety, which we would have to place directly above our heads facing down.
My questions are: Are down facing rears directly above the listening position a good solution that would also sound more natural that what we have now? Or should we go with hanging speakers that are off to the side and face inward? If we go with the latter, what brands would timber-match my current speakers?
Thanks in advance for any help and/or advice!
