Hey everyone,
I'm new to the forum, although I have used it periodically in the past for research purposes.
I am looking to upgrade my antiquated receiver to one which possesses HDTV ( component / HDMI ) switching.
I am looking to spend between 1,000 - 1500 dollars.
I have researched the following models; the Denon AVR-3806 and the Rotel RSX-1056. I am also open to any suggestions you might have, as well as upping my budget to 2k if I can improve quality/functionality by going to separates.
I run my system off NHT model 1.5 speakers with SuperOnes acting as the center and rear channels. I use the system primarily in this respect; 45% HDTV, 30% DVD Movies, 15% Music and 10% video games.
I am looking for something that is versatile, high quality, and will be able to handle next gen hd sources ( ps3, hd-dvd, etc).
Another questions I have is whether HDMI/DVI will offer significant improvement over component cables. My HD-DVR and upconverting Denon DVD player both have DVI output. If this is the case, then I would lean towards the Denon AVR-3806 which contains HDMI switching.
I would like to thank you in advance for any advice you could offer.
-Dean
-Dean
