Patrick Zapatka
- Dec 11, 2000
I have been eyeing an M&K S-150 THX 7 speaker setup (S-150 L, R, BL, BR, SS-150 SL, SR, and S-150AC) for quite awhile now, and am hoping to get some feedback before pulling the trigger next month.
I primarily will use them for home theater, and have heard them extensively in a home theater room at a local dealer. They will be matched up with an Onkyo TX-DS989ver2 and an SVS 20-39PCi. They will be replacing an Energy Audissey 7 speaker setup thay can be seen at http://home.comcast.net/~pzapatka/hometheater.htm .
Is there a reputable on-line dealer that carries them (with full warranty)?
Is there any other setup I should listen to?
Thanks for any advice! Cheers,
Patrick
Patrick
