Rob Gillespie
- Aug 17, 1998
Bit confused about this thing. I've got the card installed, it was detected and installed OK automatically.
I try and perform an capture from LD in Vegas Video (it's the 3.0 LE version). All seems ok until I stop the capture and try different settings or another titles, or whatever. Then I get a totally blank capture screen, as if the card itself has turned off. Nothing. Not even audio.
The system seems to think it's a digital camcorder, with play, pause, forward buttons etc - and the playing time clock in the software never stops advancing - as if it thinks a 'tape' is playing all the time. There are no settings I can see to get the think working again - I have to power off the PC and start up again (simply rebooting doesn't work).
I've gotta say, for a product at this price level I was expecting maybe just a bit of documentation but there's basically nothing other than an installation guide. The WinProducer software that came with it is total crap and while Vegas seems a bit friendlier there is still precious little information.
But that aside - why the blank screen?
