ADVANCED TOPIC: Motorized Door to cover Plasma over Fireplace
Discussion in 'Home Theater Projects' started by tonyGar, Feb 18, 2006.
  1. tonyGar
    tonyGar Agent
    Jan 2, 2006
    35
    My wife wants to conceal the Plasma TV over the fireplace with a motorized panel that comes down behind the panel over head...like a vertical motorized drop down door (ala Get Smart!!)....
    How can my carpenters pull this off? Is there a motorized system that can be used in custom carpentry projects?? I presume there must be some kit with a motor out there!!
    HELP!!!
    Tony
  2. drobbins
    drobbins Screenwriter
    Dec 2, 2004
    1,872
    110
    Dave
    Tony,
    I saw another option that you might consider at a local HT store. They have an one way mirror that is mounted in front of the plasma TV. When I first went into the store, I thought it was just a fireplace with a mirror above it. The salesman hit the remote, and the mirror turned in to a TV. They also had some Stealth Speakers. I didn't even know they was a HT there until it was turned on. Looked good.
    Dave
  3. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
  4. joetraff
    joetraff Auditioning
    May 17, 2010
    2
  5. Tonni
    Tonni Auditioning
    Jan 27, 2011
    3
  6. Tonni
    Tonni Auditioning
    Jan 27, 2011
    3
  7. Zubaer
    Zubaer Auditioning
    Jan 28, 2011
    3
