Advance Wars Question (1 Viewer)
Dean Cooper
I got this game used with no manual so I have a stupid question I'm hoping that someone with a manual will be able to tell me the answer to. How do you reset the name that is entered in to the game? is there any way to delete the save game that is in the cart so I can start fresh?
Dean
Ben Seibert
Press the L button, Select, and right as soon as you turn the GBA on. You should then be given an option to delete your saved game.
shooje
