dvdclon
I noticed inline ads this morning in some of the forums even though my subscription still has a month left on it.
Is something amiss?
Is something amiss?
There was a problem earlier today that has since been fixed. Try clearing your cache.
Guys,
When we moved to this platform some members subscriptions got lost. We are still working on this - @Adam Gregorich is taking the lead. PM him if you run across a problem.
You can disable your adblockers now - as i've fixed the issue for both of you.
My Supporter tag is back, thank you, but when I disable my adblocker, the ad between the first and second posts comes back. It's just as I reported at the beginning of this thread. The ad I see right now mentions emailaccessonline.com which is reported to be malware/adware.
No change, Adam. It's still showing up. I also tried it with another browser, which I hadn't used with HTF to rule out cache and cookie interaction. No help there either.I got yours fixed David. Can you turn off your ad blocker and try again? I will have the rest fixed this week.
Thanks David - fixed that now.
