DonnyD
- Jun 12, 1999
Having spllit my sub out signal to run my SVS and the amp for the bass shakers, I find that the recommended -5 (or so) lfe setting to set the sup properly just takes away too much from the shakers. How is everyone else doing this?
I have a RXV1 receiver, 20-39PC SVS.... shakers are pro auras driven at 4 ohms by a M45 Yamaha amp (full volume), 120wpc. Ought to be far enough to pound the shakers, nevertheless, the -5 sub level just takes too much away. I found myself running a 0 sub level setting and adjusting the gain on the svs but then the sub will bottom on loud passages. Balancing these 2 is hard as hell to get the most out of each.... any advice is appreciated.
