Adire Shiva, AVA250
Discussion in 'Home Theater Projects' started by Gianluca, Jul 1, 2003.
  1. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    Hi everybody,
    does anybody have this configuration:
    Adire Shiva
    AVA250
    Qtc 0,6
    What do you think of it? Will I get good results with music?
  2. Jay_Garcia
    Jay_Garcia Extra
    Jun 11, 2003
    19
    I just did a 54L sealed Shiva with a PE 250W (Q=.707) and it is awesome for both music and HT.
  3. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    I could swear we just answered this question. It's like Deja Vu all over again [​IMG]
    Q of .6 for music
    Q of .707 for combo HT/Music
    IMHO of course.
  4. Jay_Garcia
    Jay_Garcia Extra
    Jun 11, 2003
    19
    HAHAHAHA [​IMG] Tim, I had that feeling too!
  5. Chris A H
    Chris A H Stunt Coordinator
    May 10, 2002
    172
    Has anyone done a Shiva in a Q range between .6 and .707? Would a Q of .65-ish (about 70L sealed) be a slighty-better-for-music sub?
  6. TimForman
    Dec 4, 2002
    847
    Technically yes, but would you be able to tell the difference?
  7. ChristopherD
    ChristopherD Stunt Coordinator
    Mar 28, 2002
    107
    I'd go up to .659 just to be safe.
  8. TimForman
    Dec 4, 2002
    847
    Obviously, a large part of DIY is experimenting and the enjoyment of testing ideas and learning from the results. The other side is wanting to get good results without a lot of trial-and-error. I would tend to give the folks at Adire some credit for doing good testing and then offering their results to the DIY crowd. Those numbers from the 56 liter and 85 liter enclosures have been tested and offered to us as good solutions. However, if you're really curious about it the only way to know is to build it and listen for yourself.
  9. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    The room has such a large effect on preceived "Q" that I'd be surprised if anyone could really tell a difference between .6 and .7.
  10. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    I didn't mean to start a silly thread: I am a newbie and need advices.
    Why would you say that
    0.6 is more for music
    and
    0.707 combo HT/music?
  11. Jack Gilvey
    Mar 13, 1999
    4,948
    Sounds about right.
    Hey, we're neighbors! [​IMG]
  12. ChristopherD
    Mar 28, 2002
    107
    I think he was asking why the sound produced from a .6 sounds better for music and sound from a .707 sounds better for HT.
    Forza!
  13. CarlDais
    CarlDais Stunt Coordinator
    Sep 24, 2000
    56
    Gianluca....Jack's correct ( imagine that?!) in asserting that the differences between a Q of .6 VS a Q of .7 is small and might just well be overshadowed by the effect of the room itself & the x-over.
    Basically, the differences will be heard in the transient respsonse and where the Freg Respsonse curve will exhibit a bump, secondly in the roll off.
    Not to confuse the issue further but I think where you'll hear and perhaps appreciate the differnces in Q values is when you compare apples to oranges, i.e., A sealed Q of .7 VS a Vented Q of .7. Or any other Combonation. My Vote will be for Sealed in a music system and a vented in a dual purpose set up. The Q is up to you. And most people over look the effects of Filter theory....both active/passive &
    acoustical/electrical.
    Build the mid Q Adire alignment and opt for the better HS-200 amp. E-mail Adire and Ask.
  14. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    CarlDais, why would you use a vented system for dual purpose? Where would the difference be? Frequency response?
  15. TimForman
    Dec 4, 2002
    847
    I think he's suggesting building one sub for music and second one for movies. Sealed systems don't extend as low but offer flatter reponse. Vented systems tend to extend lower but may not be as flat.
  16. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    I just tested the sealed SHIVA with a 0.6 Qtc on the .xls sheet I found on the www.diysubwoofers.org
    The results are pretty good!
    The sheet tells me the frequency response and the supposed in-room response...
    It looks very good, and as I am more interested in music than movies... I think I will go for the sealed one!
