Bert D
- Dec 14, 2001
I just took the plunge and ordered the Rava from Adire.
My question is on set up. My emphasis is on stereo music listening with HT as a secondary concern. Being new to all this, (first new equipment purchases in 15 years!) I get a little lost when reading my receivers instructions on set up with a sub and am not sure how to go about it.
I have all JBL speakers: S310's mains, S center, S38's surrounds with a H/K 310 receiver and a Panny rp56 player. I plan to set all my speakers to small, then all signals under 100 hz gets sent to the LFE output which is fine when I play dvd's if I hook up the sub to the LFE. But when I play stereo music I have no sub this way, so not good for me. I want the sub to be active with both music & HT.
I have an option to set the receiver to LFE+front mains, but that sends below 80/100 hz to my mains, and I want my mains to cut out at 80/100 and have the sub do the 80 below duty in both modes. If I use the speaker level inputs and set the mains to large, sent it to the sub, cross the sub at 80, and have the sub send 80 and above to my mains, all sounds fine except according to my receiver, with no LFE output and my center/surround set to small, I loose the 100 and below to these speakers in HT ?
Is a solution to hook up my sub both way's ? , with both line and speaker wired up and switch back and forth depending on Ht or music ? Sorry for being long winded and being new to all this, my question may not make any sense.
What do you think ? Thanks.
