Rob Lloyd
- Mar 22, 2001
I finished my Adire LCC kit. (Before Brian I think).
It sounds great. Only one complaint (Dan you listening?)
I wanted to recess the drivers. No problem with that but the hex head screws Adire sends you for the t-nuts have about a 3/4" flat section (no threads). With the drivers recessed there isn't enough thread left to tighten the driver down. They either need to use the same ones as the 281s or get different ones to send.
I ended up using the ones from the 281 kits (I used screws on those). Unfortunetly they aren't the same size thread. Just a hair smaller. So they hold but not perfect.
I also built a pair of 281s with rounded edges, finished using the patented Pat Sun method
Anyways. Here's the link to the Pictures.
Rob
Rob
