Adire HE10.1 in sonotube?
Discussion in 'Archived Threads 2001-2004' started by Jim J, Feb 25, 2002.
  1. Jim J
    Jim J Second Unit
    Mar 28, 1999
    290
    How would that work out? use a 10 or 12" tube, vent in the back? or 14-16" vent in front. any non-vented alignments?
    seems like it would be easy to make. how long would the tube need to be?
  2. Doing so COMPLETELY changes the diffraction pattern. You'd need a lot of Xo tweaking toget it back to the original state.
  3. DanWiggins
    DanWiggins Second Unit
    Aug 15, 1999
    324
    Jim,
    As Anthony alludes to, you'd need to change the crossover for optimal performance. We designed around a given baffle dimension/shape, and while small changes to that aren't a problem, large changes (such as moving to a round baffle) can be.
    HOWEVER, how about cutting a rectangular baffle, and sticking it across the end of a 12" diameter tube? This gives you the ease-of-construction I think you're heading for, but maintains the baffle dimensions.
    Venting can be run out the back without a problem; this does limit how close you can place them to a wall, however. Leave at least 6" between the vent and the rear wall in the situation.
    Dan Wiggins
    Adire Audio
  4. Jim J
    Jim J Second Unit
    Mar 28, 1999
    290
    wow, thanks guys. quick response
    hmm. the rectangular baffle would make things easy. I was also thinking in terms of 'cool' factor. using all tubes to create an eventual Sono-System :)
    thanks for your time
