Adire AV3 sub/sat system
Discussion in 'Archived Threads 2001-2004' started by Kyle Richardson, Mar 13, 2002.
  1. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    I just completed these last night. The sats are 4"w x 5"h x 4"d and use the $18 Adire AV3 full range driver. The sub is just under 1cu ft and used an 8" Dayton driver that also costs $18 and is powered by their least expensive plate amplifier ~$95. All are finished in birdseye maple veneer with 3 coats of poly over the top.
    How do they sound? Not at all like $18 drivers! The sats have quite a large soundstage and are very nice. The sub is very impressive and belts out the bass. There is a small hole in the frequency between about 200Hz down to 160Hz where the sub starts to take over but it's a small price to pay for the small size and inexpensive drivers used.
    If anybody wants to build their own sub/sat system this is a very good way to go. For 2 sats and a powered sub the hardware will only cost around $160! It would also be a very good learning project for somebody since there are no crossovers involved in the speakers either.
    Kyle Richardson
    Acoustic Visions
  2. Fred Seger
    Fred Seger Stunt Coordinator
    Aug 13, 2000
    136
    Looks Good!
    I've been thinking about making a set something like this for my computer. And at that price why not..
  3. Martice
    Martice Screenwriter
    Jan 20, 2001
    1,077
    That system does look good Kyle. I'm building a new computer and it may come in handy soon.
  4. Kevin Deacon
    Kevin Deacon Second Unit
    Dec 18, 2001
    319
    Do they sound better than Bose?[​IMG]
    They probably kick the pi$$ out of Bose. Nice work. Is the back of the sub birdseye?, what is the rest made of?
  5. Kyle Richardson
    Jan 1, 1998
    1,073
    Yes, they do kick the pi$$ out of Bose for much less $$. All of the veneer is birdseye over 3/4" MDF for the sub and 1/2" MDF on the speakers.
    Kyle Richardson
    Acoustic Visions
  6. Kevin Deacon
    Dec 18, 2001
    319
    Did you stain the front and sides of the sub a dark color? In the photos it looks real dark, while the back looks light like the satellites.
  7. Kyle Richardson
    Jan 1, 1998
    1,073
    No, everything was done with the same oil, poly, and veneer. I think it's just the lighting playing tricks with the pictures.
    Kyle Richardson
    Acoustic Visions
  8. Kevin Deacon
    Dec 18, 2001
    319
    That is a really strange lighting effect. I notice this because I am heavy into photography. Notice the photo with the satellite sitting on top of the sub: the sat is light colored, but the front and top of the sub is much darker. It's like the photo was digitally manipulated in Photoshop or something, strange.
  9. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    That's because the sat is sitting on top of a Kit281, not the little sub. [​IMG]
  10. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    haha, way to point that out Michael [​IMG]
  11. Ben Ven
    Ben Ven Stunt Coordinator
    Mar 6, 2002
    61
    Kyle,
    How does the top end sound? I know the top end will be compromised, I am just wondering to what degree. (Hey, I can't hear past 15 kHz anyway-old age you know!!) I have toyed around with the idea of using a single full range driver for my mains and center channel for years. I currently have full range drivers, from Audax, in my rears and they sound very good in the rear. A single driver eliminates a few anomolies that multiple driver configurations can cause, such as time alignment issues, phase issues, the lack thereof, due to the absence of a crossover and lobing concerns.
    Hope to hear back on this issue.
    Thanks!
  12. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Kyle, are the 4"x5"4" dimensions the outer dimensions or the inner dimensions for the boxes?
    I'm toying with the idea of building the SBB4 alignment (3.5 liter enclosure ported with a 1" wide port 2.5" long) with the AV3's because I want better PC speakers without the need of a sub.
  13. Kyle Richardson
    Jan 1, 1998
    1,073
    Ben, the AV3 will extend to 16Khz so I think they will be fine [​IMG]
    Patrick, those are outside dimensions.
    Kyle Richardson
    Acoustic Visions
  14. Blake Middleton
    Feb 28, 2001
    46
    Kyle,
    Adire recommends I think 4"x6"x5". How did you come up with your dimensions? Would there be much of a difference?
  15. Kyle Richardson
    Jan 1, 1998
    1,073
    The T/S parameters listed on Adire's site are of the original AV3. The current AV3 has the following parameters:
    Qts .51
    Vas .7 l.
    Fs 130 Hz.
    Re 3.4 Ohm
    Xmax 2 mm
    Qms 3.30
    Qes .60
    Sd 30 cm^2
    Mine are just under .5 liter which will drop the low end a little sooner but it was a small sacrifice to obtain the smaller box.
    Kyle Richardson
    Acoustic Visions
  16. VinhT
    VinhT Second Unit
    Feb 14, 2002
    357
    Kyle, the T/S parameters you gave for the new AV3 are quite an improvement. In a 1.5 liter (.053 cu. ft) vented enclosure tuned to 94Hz with a 4" long one inch diameter port, the F3 is around 90Hz. If the AV3 really extends up into the 20kHz range, that makes for an amazing little speaker. It's so enticing that I'm seriously thinking about doing a complete home theater set using them since I'm not yet knowledgeable enough to be working with crossovers.
    There are just a few questions I have:
    -Are the AV3s 4 or 8 ohm? The Adire Audio site states the Re as 3.4 ohms, but I'm not sure what exactly that means.
    -Being rated at only around 15W, can the AV3 be used with regular A/V receivers in the 60W-100W range? I know speaker damage is more likely to be caused by clipping than by too much power, but would such a large difference cause a problem?
    -As the sensitivity is somewhat low at 85dB, would it help to use two drivers? I don't quite yet understand the relationships between number of drivers, required power from the amp, and output levels.
    Any help would be greatly appreciated. [​IMG]
